ken56's avatar
ken56
No good deed goes unpunished
Here's the story. I had a friend ask me to come over and look at why his battery was not charging. He has a 2012 model travel trailer. He was plugged into shore power at his home so I just popped off the battery cables and put the meter on them and it showed nothing. I told him his converter was not charging and he likely needed a new one. He buys one and changes it out and we look again at the battery cable charging output and voila, he has 14 volts.
NOW he says he also changed out the circuit breakers on the tongue and he now thinks that was the problem and not the converter. I explained that the battery cables came right from the converter and the current doesn't pass through those breakers to charge the battery. He says I'm wrong. AM I??
  • After several negative experience's helping friends and strangers, I finally learned my lesson after 40 years. Now I play ignorant, sorry, but that is how it is.
    When I help someone change a tire and then they blame me because their car will not start, well, that was the end of it.............
    When I jump start their car and then they blame me because the radiator is leaking, well, that was he end of it...........
    When I changed a fuse for a stranded motorist and they blamed me because they ran out of gas, that was the end of it............
    Etc., Etc..........
    I am obviously a slow learner...............
  • Some friend! No matter the outcome, be sure to let him know that asking for your help in the future will be a non-starter!
  • As said "plug in the old converter and test the 12v output. "
  • Easy enough to plug in the old converter and see what happens.
    Your friend is immensely ungrateful either way though..
  • He is probably correct that there is a circuit breaker. Best would have been a voltage check right at the converter. However since power was restored with a new converter the breaker could have had an intermittent fault. And now it is he said she said because you did not observe the work. And we still don't know exactly what was done during the swap or what breakers were replaced.
    Otherwise it is on him for agreeing with you on the diagnosis.
    Offer to buy the beer next trip...
Having RV issues? Connect with others who have been in your shoes.24,322 PostsLatest Activity: Oct 07, 2025
