jay_kinsaul's avatar
jay_kinsaul
No headlights problem please help
So I just got a 1984 pace arrow in like new condition and everything but the headlights are not turning on. The switch apparently works cause I can turn on my running lights and dash lights and it dims like it should just no headlights at all. I have even tried hitting the brights switch on the floor and it don't do anything either not even the lights for bright for brights light up. So none of the four headlights work dims or lows. Any pointers and advice would be greatly appreciated
  • I will have to check that next time I go to it. I hear the switch work but like I said the blue light indicator for brights don't come on
  • Check for power at your high beam switch with the headlamps on. Should have 12 volts going in and it'll have 12 volts coming back out on either the high beam circuit or the low beam circuit. Also check the connector down there for corrosion and wires broken off
  • It's got the Chevy chassis wit the 454. I saw somewhere on Google that there's a circuit breaker on the switch itself
  • Matt_Colie wrote:
    Jay,
    You don't say what the chassis but most have the headlights on a separate fuse that is in the fuse group. Now you just have to find it and hope it is bad and that is all that is wrong.
    Matt
    Headlights are NOT fused. The lead for the headlight switch comes straight from battery power. The headlight switch does have a circuit breaker built in.
    The headlight switch does have separate circuitry for the headlights and the parking/running lights. So the switch may be bad, even if the running/dash lights work.
    You need to get out your VOM and check for voltage all along the wiring path for the headlights.
    Richard
  • Jay,
    Matt
  • jdc1's avatar
    jdc1
    Explorer II
    Start by disconnecting the wiring. Clean those connections with baking soda and water, then apply dielectric grease when re-assembling.
