MrWizard
Mar 16, 2022Moderator
Doug thank you, I will look again, to verify no access panel on the enclosure,
Then attempt to remove it by sliding it out,
Not knowing for sure that there are flex hoses, was a big concern,
The burner does come on, it does make hot water, opening the over temp valve gives a strong spray of hot water,
The number is correct no EXT no heat exchanger
I was hopping you or someone had serviced this exact setup and knew positively how it is installed,
