dougrainer
Mar 17, 2022Nomad
MrWizard wrote:
Doug thank you, I will look again, to verify no access panel on the enclosure,
Then attempt to remove it by sliding it out,
Not knowing for sure that there are flex hoses, was a big concern,
The burner does come on, it does make hot water, opening the over temp valve gives a strong spray of hot water,
The number is correct no EXT no heat exchanger
I was hopping you or someone had serviced this exact setup and knew positively how it is installed,
It all depends on the OEM. I have had Winne and Fleetwood and Monaco that you had to pull the Water Heater to access the back where the water lines are. I have also cut my own access panel instead of pulling the W/H. I cut the back of the galv back wall IF I have at least a foot behind that panel. Using an Air chisel with a metal cutter blade, I can do this is less than 2 or 3 minutes. I then install a larger plate to cover the hole. This way, you always have access for the future. Doug
