MrWizard
Mar 18, 2022Moderator
Barry I think the heat is mainly conduction via the water itself, like heating one end of metal rod,
And look closely at those drain tubes, the brass elbows and the tight clearances, and I'm quite sure there are more elbows inside the enclosure behind that wall, broken parts from the check valve are back there inside the tubing inside the enclosure, NOT accessible at this time
Doug not sure it's clear in the photo, there is room behind the box, to cut into it, but I would much rather not do that, but I will if that's the only way,
I have No Air Tools, most require more CFMs than my compressor can supply, hand tools & electric tools, No pneumatic hammer, I have a nice electric Impact wrench for Lug Nuts or Bolts that need loosening
I have to restore hot water flow, I am not a cold shower person, especially Not ..cold weather, cold water from the fresh water tank,
