MrWizard
Mar 18, 2022Moderator
The picture looking up from underneath is not very good, the perspective is off, so is the lighting,
The longer box at the top of the picture is an RV LP heater for.the.rear of the RV, it is located directly over the water heater, shorter box is the water heater, I took the picture while laying on my back under.the RV,
Looking up at angle
Perhaps the picture of the side of the RV, will help some members understand,
You can see the W.H. Located Between the rear Mor-Ryde tag axle and the door for the Utility Bay/wet bay
Open the bay door, and you see the waterline pix in the first post
This image below, is looking up from under the RV, shows the LP lines for heater/furnace & WH
Looking up at angle
