MrWizard
Mar 27, 2022Moderator
Jbarca,
Thanks for the pictures, I can pry the cover enough to peek inside and can see the line connected to the output at the top of the WH, the line has a plastic fiting with finger wings,.
But I can't get my hands in there yet, and was Not able to.get a picture , going to make another attempt shortly
Richard I hope your water heater is easier to get at.
Because
If you have a 36S like this one, your in for a heap of frustration,
I'm turning off the propane, letting the fridge burn it off, then use the angle grinder to cut the cover plate,
I don't have air tools & chisel, and the saw blade on the multi tool is not up to the cutting job on this steel plate
This should have been a simple job with minimum hassle,
It has been everything but that, with one obstruction after the other
Because
