Bobbo
Mar 28, 2022Explorer III
schlep1967 wrote:
Wizard, What is that wooden wall right behind your pic of the installed check valve? If you can access that from the other side, that would get an access panel added if it were my camper. That way when you get a replacement check valve, available at any Lowe's of Home Depot, you can easily replace it.
If you install a permanent access panel, I would opt for a shut-off in that water line and forgo the check valve. Change from a 1 valve system to a 2 valve system.
