MrWizard
Mar 28, 2022Moderator
Schlep
I installed it the correct way, there was no way to put this one.backwards, in this install, input end is male threads into the wh, the output is female, brass elbows is male on both ends , HW..line female connect to elbow,
Found the plunger/gate no spring, the first elbow in the system is the one attached to check valve, I think that spring rusted away sometime ago, nothing but water came out when I blew out the line
Before cleaning
Before cleaning
