Bigdog's avatar
Bigdog
no power from generator
Fired up the gennie and shock it started. Been having problems with that,but different problem. While I had it running, I decided to add a load to it, so turned on the A/C and the convection oven. No go. Checked the fridge and it was still operating on gas, then checked the power board and it wasn't showing any AC input, even after changing it to 50 amp. After running the gennie for a bit longer, I shut it down and plugged back into shore power and everything worked as it should.
Wondering if this is the transfer switch and how do I test it? Fire up the gennie and put a tester on it to see if it's getting in? Way too long wait times to get it done at a shop.
  • How long did you wait before deciding you had no juice. My generator runs for a minute or two before the transfer will automatically occur.
    Dave
  • genny will have 1 or 2 circuit breakers on it. Reset them.
