Jonnygsx
Jan 09, 2014Explorer
wif wrote:
The EX650 doesn't have brushes or a commutator. It uses a small magnet on the rotor to induce a small current in a sub-winding in the stator. This current charges a condenser which is used to kick-start the generation process. You could have a bad sub-winding or main winding in the stator or a bad magnet on the rotor (sometimes a sharp knock can ruin it). Could also be the condenser itself or the wiring connections to any or all the above. Because it's not a conventional type generator (brushes, etc.), you cannot "flash" it. Try the EX650 pdf here: EX650 troubleshooting
Ah thank you for this link, all I could find up to now was the basic manual. I will check this out with a meter tomorrow.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 01, 2026
