wa8yxm
Jul 14, 2022Explorer III
Wurtzberg wrote:
Battery reads 13.6 volts, when connected to shore power WFCO 8735 is not sending power to battery.
I have 12volt for lights when on shore power but no lights when boon docking
Many Thanks for any suggestions
ARE you measuring AT THE BATTERY? or at the indicator panel. (Panel measures converter out..
If you have 13+ at the battery then the WFCO is sending power to the battery for the battery resting voltage is less than 13.
WFCO's are noted for not going into BULK
Suggest a Progressive Dynamics
IF the WFCO is an intergrated power distribution center/converter the 4600 series IF its a stand alone box. 9200 series. try to match the last two digits of the model as close as possible.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
