DiskDoctr
Jan 22, 2018Explorer
Joeycockerspaniel wrote:
OK, here is what has apparently happened. My coach has a battery isolator solenoid...Thanks for the help. Hopefully this will remedy the problem.
That's good news you found the problem :)
Be prepared to replace many of the electrical connectors, they tend to rust on all the isolator terminals and such. If so, figure anything that has a terminal on it will be kaput when you try to spin the nuts off :E
Good luck getting it worked out and as Mex has shown, it's smart to post up your proposed solution and parts to be checked before you spend the money on them ;)
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
