chefdc1's avatar
chefdc1
No power to fridge outlet.
Newbie with 1997 Damon Hornet 2754B Ford with no power to fridge.
Hello friends! Looking for advice. There is no power getting to the outlet that my fridge plugs in to. The fridge runs fine when I plug directly in to an extension cord. I have checked the outlet with a multimeter and get nothing. The breaker on the main panel seems fine. I can only find one GFI (in the bathroom) and it is fine. Any ideas...am I missing something? Other outlets are fine. Thanks for any advice/ thoughts.
  • Look around the rig for a GFCI receptacle. It could be tripped.
    Many times the element for the refer goes to ground tripping GFCIs.
  • If you haven't pulled the cover off of the outlet, do so, I think it's possible there is a broken or loose wire at the back.
  • It runs up through the walls of the coach. I might need to get some help on this one. I'm still holding out for a simple fix.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
