144Grayling's avatar
144Grayling
Explorer II
Mar 21, 2022
No power to gas water heater switch
I have a 2008 Komfort TT with an LP only water heater with automatic spark ignition. It was working just fine, then all of a sudden it would not light. Only cold water from the tap. There is gas, but no voltage at the on switch. We are on shore power. Other 12 volt things work (lights, range hood) but not the water heater. There is no fuse in the control center labeled ‘water heater.’ Any help for hunting down the problem would be appreciated.
Thanks!
