enblethen
Mar 22, 2022Nomad
wrong way to measure switch! You would use resistance scale between switch contacts.
You need to check volts with black lead to ground, red lead to switch wire with meter set on 20 volts or close.
Check all fuse with meter set to 20 volts, black lead to ground red lead to fuses. Check both sides of each fuse.
Red light should come on until water heater lights then goes out. Will come back on if error. Red light is fed from circuit board blue wire.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
