jpddet220's avatar
jpddet220
No power to Onan Quiet Diesel
Hello,
I have a 2008 Jayco Seneca with an Onan 5000 Quiet Diesel. After returning from a trip, i discovered one of the positive cables to the coach batteries became disconnected due to a battery terminal nut falling off (from road vibrations). I reconnected the positive cable and reestablished battery supplied power to the coach. However, there is no electrical power to the generator. Does anyone know if there is a fuse for the generator, and if so, where is it located? Thanks and Happy Holidays.
Ted
  • Fixed it! Yahoo!!! There is a small panel on the generator above the start/prime switch. Removed the access panel and found two 15amp mini fuses. One was bad. Thank you all so much for your suggestions and help. Happy New Year and safe travels.
  • Check for 12v at the switch...could just be a bad switch...also check the generator itself as I have seen remote disable switches on the generator...does the gene start at the generator with the switch there?...if so, then there could be a harness that goes to the switch near the generator loose...if not, then it could be more serious with gene itself and to ONAN it goes which I truly hope not...I would also call Jayco and check to see if support can tell you where there might be a fuse or better yet, exactly where the harness is that carries power to the generator.
  • Thank you all for taking the time to read and answer. I pulled the battery tray out and all vables are connected. Test light showed power going to the generator. Unfortunately when i push the start/prime button on the generator, noting. Light does not come on, doesnt activate the fuel pump or anything. Does anyone have any suggestions before I take it to ONAN and pay for their kid's college tuition?
  • There may be another wire on the batteries that supplies power to the generator. Check for another cable near post that became loose.
  • Just guessing , but I would look at your wiring diagrams to see if there may have been another wire that fell off that went to the generator for some reason.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
