TinnCanMan's avatar
TinnCanMan
No power to outside GFCI plug
I have 2014 Keystone Laredo 30' TT.
Recently, my outdoor plug lost power. Putting a volt/ohm meter to the plug and then to the romex cable, I got no 120v read, just a slight voltage reading.
I traced the cable back into the RV and it goes up into the ceiling!?! Not sure why it's routed there seeing that the power station is right behind the exterior plug.
Does anyone have a wiring schematic for this model if it exists? Or can anyone guess-timate why it would be routed into the ceiling? I'm assuming it's going to the other GFCI plugs in the trailer; 2 at kitchen sink pedestal (only route is under, not over) and the other in the bathroom just to the right of the power station.
Any advise would be appreciated.
Thanks - JD
  • Got if figured out before I read RoadAbode's post.
    I opened up 2 walls and followed the romex back to the bathroom plug, which has the reset button. Took the plug out of the cardboard wall and yes, one of the power leads to the outside plug had come loose. Popped it back in and all is well.
    Thanks you all for your comments & assistance.
  • TinnCanMan wrote:
    the other 3 GFCI plugs work fine (2nd thing I checked) and so does the refrig. My GFI plugs are wired to the same 15A circuit breaker & it's not tripped - aside from the other 3 plugs working okay
    Since that Plug only has sticker, it's "downstream" from one of the GFCI plugs that has a reset/test button on it. Check to see if one of the wires became loose from behind one of the plugs that would be "upstream" from this one. The GFCI must be connected to one that has the rest buttons.
  • the other 3 GFCI plugs work fine (2nd thing I checked) and so does the refrig. My GFI plugs are wired to the same 15A circuit breaker & it's not tripped - aside from the other 3 plugs working okay
  • Not same but similar issue I experienced. Outside plug and fridge was not working. Turned out the power to those was routed through the GFI in the bathroom, which one of my girls tripped while blow drying their hair. Reset and all was good. Took a while to figure that out. Hope yours is as easy to figure out. Good Luck!
  • RoyB's avatar
    RoyB
    Explorer II
    My OUTSIDE 120VAC Receptacle is paired to the Kitchen GFCI receptacle. Sometimes it is hard to see those thing have tripped... Try resetting all of your GFCI receptacles in the trailer. Anywhere there is accessible water you should have one. I have three inside my 5th wheel trailer (Kitchen-Bathroom-Bedroom wash-up sink).
    Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
