RoadAbode
Jul 11, 2015Explorer
TinnCanMan wrote:
the other 3 GFCI plugs work fine (2nd thing I checked) and so does the refrig. My GFI plugs are wired to the same 15A circuit breaker & it's not tripped - aside from the other 3 plugs working okay
Since that Plug only has sticker, it's "downstream" from one of the GFCI plugs that has a reset/test button on it. Check to see if one of the wires became loose from behind one of the plugs that would be "upstream" from this one. The GFCI must be connected to one that has the rest buttons.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
