My converter recently went out, and I lost power to both my DC and AC appliances. I'm getting 125v in at all the breakers, and the lines that lead into the converter. My question is why have i lost po...
How are you checking for 120 volts? Do not use ground to breakers, you must remove cover from AC breakers and use the neutral(white) to verify 120 is present. I am thinking that you have lost the neutral in the shorepower connection maybe an adapter went bad when converter went out. Turn off all breakers (Don't flip them) applying light pressure toward off. Turn the main breaker on, then each of the branch breakers one at a time.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
