Mike_P_
Feb 04, 2021Explorer
No Power
New to me E450 C Class Not getting power to the rear bumper for a trailer wire plug in. Wiring in the underside rear does not look disturbed. Havn't found the fuse box yet to check for a blown fuse...
Mike P. wrote:
I know it was meant to be helpful, but..
There is at least 100 fuses spread out over 4-5 different fuse/relay boxes which may be under the drivers side dash, under the passenger side of dash and both sides of the engine bay..
Add in the fact that the OP is dealing with a "E450 Van chassis" RV fuse boxes often get moved or rearranged by the RV manufacturer..
Finding and testing every single one of those fuses without a game plan will result in a lot of frustration..
Especially considering there ARE "charts" that give locations and function of fuses..
Additionally, most fuses use in modern automobile applications are the even smaller ATM (MINI) plastic fuses which will make even more challenging to nail with meter leads..
ATC vs ATM FUSES
