If you remove the access panel in the storage compartment on the side facing the hot water heater, you will see it mounted to the floor. Mine is just past the vacuum canister installed in mine
Late model converters have reverse polarity fuses. They could be in the 12 volt DC distribution panel commonly located adjacent to the 120 volt AC circuit breakers behind a metal plate hed on by a thumb screw.
All receptacles work…I’m thinking an in-line fuse that charges battery from pedestal? We were hooked up to 50 amp but after a few days we had no lights because battery was dead. I know the lights are 12 volt…we had microwave at the time but no fridge
There was power from pedestal and microwave had power. The new battery did not seem to charge and I had to have a battery charger on it all week. Cannot tell if inverter was running because I can’t locate. I checked all possible breakers and fuses that I can find.
Having RV issues? Connect with others who have been in your shoes.24,358 PostsLatest Activity: Feb 08, 2026
