Alfred622
Dec 22, 2013Explorer
1) do you have a low point drain just after the pump? If so open it and turn pump on - that will tell you if pump is pumping. If not, then it could be a problem with the pump or prime.
2) Can you run city water under pressure into your TC? That will tell you if the plumbing to your faucets is good.
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 30, 2026
