Led_67
Dec 22, 2013Explorer
sign man wrote:sign man wrote:
okay so i connected city water hookup and that worked fine. but when i use the pump it barely pushes water out but yet it still does. just with no pressure and the pump wont shut off
okay the pump stopped after 10 minutes and when i turned the water on water came out for a short time with good pressure but then stopped giving water and the pump would not shut off again
From the above post I would say you either have a pump going bad or possibly the pressure valve is malfunctioning
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 30, 2026
