boatms03
Dec 23, 2013Explorer
I had that issue one time after TH sat up for a couple of months. It was something, maybe algae or dirt blocking the outlet of the water tank. I was able to remove the hose going from the tank to the pump and blow back into the tank and cleared the line. it may be a partial block since you do build up pressure eventually, but when you open a faucet and the pump starts pumping there is not enough water to supply the amount the pump is pumping.
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 30, 2026
