sign_man
Dec 23, 2013Explorer
MNtundraRet wrote:. It seems to me that if there was a leak that the pump would never shut off but it does.
Have you got outside and looked for leaking water?
Did you replace the hot-water heater plug?
Water leaking out the hot-water pressure vent? Cycle it a time or two.
Check under sinks in cabinets for leaks. Connections should be tightened every so often. Check the inline strainer connected to the pump. Check and clean faucet screens.
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 30, 2026
