TheKunkels's avatar
TheKunkels
No water in toilet
I'm sure this is asked somewhere on here but too many to search through.
My toilet has no water coming from the top of the bowl. When I flush I can hear water but not see any. It's a Thetford brand.
Any ideas ?
  • Your right Chris. It was # 11. It just slipped out of place and was laying down blocking the throat of the toilet. Yer right a messy job. I removed the toilet then split the top from the base and pushed the tube where it belongs.
    Works great,
    Thanks y'all for your help.
    God Bless †
  • If it is an AMIV, there is a tube which has probably failed- #11 on the illustration.
    Part number 33312
    Your call, but it's pretty nasty to replace.
  • Gjac's avatar
    Gjac
    Explorer III
    TheKunkels wrote:
    It never gets to the bowl when the lever is pulled
    Does water get to the sinks and shower? When the lever is pulled do you hear the pump come on? Can you hear water swishing around between the inner and outer wall of the toilet? If water gets to the sinks and you can hear the pump cycle on and off with the lever and you hear water inside it sounds like your problem is after the water valve. As I remember there is a clear plastic hose that goes from the water valve to the top of the bowl, that tube is held on by spring clamps, maybe one has worked loose. You have to remove the toilet to access it. Good luck and let us know how you are making out.
  • Sounds like you are filling the belly of the trailer with water. You need to pull the toilet and test it.
  • Gjac's avatar
    Gjac
    Explorer III
    Do you mean the bowl won't hold water, leaks through seal? Or do you mean the water never gets into the bowl when the foot pedal is pressed? My Thetford has two pedals one to flush and one to add more water to the bowl.
  • Where is the water you are hearing going? Do you see water in the toilet? Otherwise I'll need to search.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
