GordonThree
Apr 22, 2017Explorer
I'm sure someone will come along and correct me shortly, but I'll take a stab.
Yellow will be your +12, black is ground. The two blue wires are tachometer output and speed control input. Fan should run at full speed without a speed control input. If it doesn't, you'll need to consult the instructions as to what sort of signal it's looking for.
Sounds like this a computer fan. Depending on if the chips inside are weak or not, it might not like the higher voltages an RV runs at compared to the smooth regulated 12.00 volts from a quality computer power supply. Someone else will likely correct me on that statement as well.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
