flyfishing48's avatar
flyfishing48
Noisy Refig
Our DM2862LBFX refrigerator makes a very annoying sound during the hottest time of the day. It was 90 here today ( Tucson) and near that yesterday. During the afternoons until just about sundown we get the noise. It doesn't really sound like a fan. Something else, but can't say what it is.
Refig seems to be working ok. Any thoughts about the noise?
  • Our 2014 four door Dometic makes a humming noise when fans are running. Does not sound like a fan.
  • This noise, I wish I could post a recording of it, doesn't sound like a bad fan.
    I will have to get a ladder and have a look in the vent openings to see if the fan is making something vibrate. If there is nothing else mechanical in there, then I guess it was to be connected to the fan somehow.
  • The ONLY moving parts on an RV Absorption Fridge would be cooling fan(s) located mid-center of the cooling unit (backside of fridge).
    Fan(s) are installed (needed) when fridge is installed in a slide out.
    Fan(s) are even installed to improve draft (air flow) needed for proper cooling
    Fan(s) are controlled by a t-stat located on condenser (fins at top) and turn on fan(s) when fill temp reaches 150*F and turn back off when fin temp drops below 130*F (Dometic uses higher temp t-stat....lower ones available)
    Fan(s) can be VERY noisy especially when failing/dirty etc.
    Depending on access.......most times one has to partially remove fridge to get to fan(s)
    Course you are aware of the fan(s) based on previous posts about your fridge
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
