23hotrodr's avatar
23hotrodr
Norcold 120 volt heating element
I have a Norcold model 6162. It blows the 5 amp fuse on the power board at times.
How many ohms should I read across the heating element ?
How many amps should this heating element draw?
I may need to replace the heating element, but I cannot seem to budge it. Is there a good way to free it up?
I don't want to use any of the corrrosion penetrating fluids on it since most (if not all) are highly flammable.
What should I do?
Thanks-- Mick
  • Glad you just had a poor electrical connection and are cooling again on shore power.
  • I'll have to try the penetrating fluids when it is not being used in season. And, I'll check for a second available slot.
    I read 39.5 ohms and2.9 amps. Sure seems ok to me.
    I've had this problem about once a year and cleaning and making sure the fuse holder clips are tight has always fixed the problem. The fuse was blowing in about 6 seconds. After a couple cleanings and checking for tightness and 3 fuses, I cleaned all connections with a metal polish (Wenol); installed a new fuse; all is fine for now.
    I would still like to work on getting the heating element loosened for future replacement, if ever needed.
    Thanks to all for all the good info and help.-- Mick
  • Mick be sure to read on Chris Bryant website. He has info and diagrams that I used to self teach myself about RV frigs when ours started to fail.
    They are quite simple devices. We had to clean our electrical connections as Chris mentioned above.
  • Should be 48 ohms, 2.9 amps @ 120 volts, 300 watts.
    Does the fuse blow violently, or just melt? These fuses do have a tendency to melt because of corroded fuse holders, but they can also have an intermittent short in the heater (short when it gets hot).
    I use penetrating fluids- they burn off quickly without igniting on 120 volt power.
  • If the barrel holding the 120v element has rusted you will need penetrating fluids I expect. Just do not put any flame on it.
    Our 6162 had an empty barrel since it does not have the 12v element being a two way frig so you could just use that one.
    When we put in the new cooling unit from RVcoolingunit.com I bought a new 120 element and put it in the spare barrel and hot wired it. Now if I loose my circuit board, etc I can manually operate the frig by plugging the spare element into the 120 volt AC outlet under the back of the frig. If I do not want to mess with replacing the dead element I will just plug the new one directly to the board.
    I do not have the Ohm's reading range at hand but google will get it for you.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
