dougrainer
May 21, 2013Nomad
You have a 2002 RV. You state your 1200 is less than 1 year old. They have not built 1200 models in years. The current model is a 1210. Are you positive about the model number. The FIRST and only thing you can do is take a 12 volt reading at the input of the recall box and the output. IF no 12 volt, you have a supply problem TO the refer from your Coach 12 volt supply. If you have in and out 12 volt from the recall box, then the back cover has to be pulled to check the 12 volt fuse on the rear control board. There is NO reset type procedure for a 1200 series Norcold refer that involves removing 12 volt power and then restoring 12 volt power or 120 power. Doug
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
