AlanB
Aug 30, 2013Explorer
Doug, This is specific to Norcold 1200 series, may not apply to any others. I understand if you order a new burner, you get the 7 slot version.
I understand your skepticism, So was I, but, hard to argue with results.
The old burner looked perfect, no corrosion, it was clean with only a slight discoloration around the slots. I was very skeptical about the burner as the old burner had nice healthy blue flame. This was not a fluke, I was very careful to only change the burner, no other changes. The new burner seemed to have a taller, narrower flame. I was impressed at how quickly it brought the temps down. The fans came on in only 15 minutes. In 30 minutes the cooling fins were at 39 degrees. The old burner couldn't do that all day long.
alanb
alanb
