hypoxia
Mar 17, 2014Explorer
dougrainer wrote:
Replace BOTH fans and the fan tstat. From the Fan tstat, run a wire from each side of the tstat down the back to behind the refer to manually test or run the fans when there is a problem. Have your 3rd fan blowing OUT the top on top the refer. Doug
Somehow I missed your post yesterday. I had seen that advice on a post you did a while back and ran the wiring as suggested. I set up the solar panel fans to run one beside the two factory fans and one on top of the vent. They both blow upwards.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
