hypoxia
Mar 18, 2014Explorer
Do the 130 degree fan switches normally fail in the open or closed position? I have an extra so I mounted it beside the other one & will hook it up in parallel if they always fail in the open position. Otherwise will just dangle the wires for future use. It is a Pines Amish unit, they claim to need just one fan & since I had four I used two on battery power & two on solar with interchangable wiring. It's easy to pull the reefer out but a PITA if it is full.
What are the thoughts on installing fans inside the refrigerator to eliminate cold spots?
I also had an extra icemaker. It was easy to replace the tray which was delaminating so now I have an extra motor.:B
Mexicowanderer, wasn't it you that suggested Harbor Freight battery chargers for bringing batteries back to life. Holy cow, have you seen their price increases for the chargers & in general? Wow!
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
