ArchHoagland
Aug 16, 2017Explorer
Norcold 1200 refrigerator fan wiring question
I have a pre 2006 Norcold 1200 refrigerator that the two cooling fans on the condenser ceased operating after the refrigerator was worked on for a heating element problem.
Research has led me to believe the tech installed the black and white wires that supply 12 volts to the fans incorrectly.
If someone who has a 2005 or older RV with the Norcold 1200 refrigerator could look at their control board tell me how their board is wired I'd sure appreciate it. There are two wires that go to the fans....a black and a white.
As you look at the control board is the black wire on the right or left connector?
You can see the wires without removing the cover on the control board.
