mxdad777
Feb 10, 2017Explorer
Now I'm puzzled. I replaced both elements and the Thermistor, put a new 5 amp fuse in and I have nothing! I'm getting 120 volts through the fuse but when I try to turn the fridge on I get nothing. I've double and triple checked that I've connected all wires correctly and everything appears fine. I might add that during this whole process I removed the circuit board from the coach to inspect all the solder connections on the back of the board. Everything looks like new on the board except for a slight heat mark behind the large blue resistor which I see is common on these boards. Any ideas what might be wrong or what I might be over looking?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
