dougrainer
Feb 10, 2017Nomad
mxdad777 wrote:
Now I'm puzzled. I replaced both elements and the Thermistor, put a new 5 amp fuse in and I have nothing! I'm getting 120 volts through the fuse but when I try to turn the fridge on I get nothing. I've double and triple checked that I've connected all wires correctly and everything appears fine. I might add that during this whole process I removed the circuit board from the coach to inspect all the solder connections on the back of the board. Everything looks like new on the board except for a slight heat mark behind the large blue resistor which I see is common on these boards. Any ideas what might be wrong or what I might be over looking?
Remember, the Refer operates from 12 volt control. Make sure the 12 volt Neg and POS feeds have voltage. Make sure you connected them on the correct spades. Make sure the recall box is connected correctly. Make sure the 12 VOLT fuse on the board is not blown. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
