mxdad777
Feb 10, 2017Explorer
Good news and I think some really bad news. I found a blown 5 amp 12v fuse and that fixed my problem and the fridge turned on and works great. The bad news is while buttoning up the project I thought I could hear a very faint hissing sound coming from just above the burner. I sprayed some windex and there are very, very tiny bubbles forming between the two tubes that the burners slide into. My guess is when removing the old burners (I had to twist them back and forth and pull pretty hard) there is now a pin hole in the cooling unit. Upon further inspection, I can see small traces of yellow around the gas burner and on the inside of the insulation that was wrapped around the burner elements. I turned off and unplugged the fridge and called it a night. Is this something that can be repaired or am I looking at a complete new cooling unit? Once again, thanks for all the help.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
