CJW8's avatar
CJW8
Norcold 1210 doubledoor not cooling.
New RV. I've been using it for a couple of months and all has been well even when ambient temps were into the 100's. It is installed in a slide.
I woke up this AM and opened the fridge door to get something and noticed it wasn't as cold as it should be. I checked the freezer and things were thawing. I was running it on electric and it has been freezing outside at night and 50's F in the day. I put a digital temp gauge in the freezer and after an hour it read 38F. Ice cubes were mushy and there was 1/4 to 1/2" ice on the back wall.
I defrosted it and dried it out. I switched it to gas. In 8 hours it is only down to 37.3 and holding.
I read that absorption (sp) refers were less efficient at freezing ambient temperatures so I blocked off the lower vents and mounted a 60 watt bulb in the back compartment. After a couple of hours running this was it is still at 37.3 in the freezer.
I am running it on 9 which is the coldest setting. Any ideas?
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 19, 2025
