Mandalay_Parr
Jan 29, 2014Explorer
Old-Biscuit wrote:
If it is 5 A (tan color),automotive blade style, it is for the 12V DC control circuit.
The 120V AC heating element is an 8 A, AGC style, fast acting fuse
The 5A blowing could be loose or damaged terminals at wire harness connector or circuit board connector
OR could be Fault in Optical Control Display overlay.
You will need to do a complete voltage check/test to ID problem.
Here is a service manual...pg. 12 has flow chart/tests for the 5A DC fuse circuit
LINK
Thanks Old-Biscuit for the clarification. I was just shooting from the hip without doing any research.
Keep up the good work.
Jerry Parr
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
