Grit_dog
Aug 14, 2022Trailblazer
One battery in a big 5ver is just the mfg or dealer being cheap. Plus assuming it was a normal 100ah ish battery, even if perfect, the 2 6v more than doubled your useable battery capacity.
However, when troubleshooting, if you make 2 changes at once, you are not really figuring out what went wrong. However performing your test with the breakers on again is easy.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
