freewayrandy wrote:
All fans are working, fridge in on a solid wall, flap is closed. Mobile tech was just here, thinks I have another bad cooling unit.
Not likely. IF all parameters are correct, then either the tech did not install the CU correctly or there is another issue on the refer. I ALWAYS lean towards the rear ventilation and the baffles that are or are not installed correctly. I would also lean towards the roof cut out not aligned to the refer or some type of foam has pushed back and partially blocked the upper roof vent flow. I have seen insulation and foam push back and partially block the free air flow at the roof vent cut outs. Doug
