prento's avatar
prento
Norcold 811r fridge gas pressure
Hi all
I have a norcold n811r fridge/freezer and the gas pressure on the pilot light has increased for some reason to the extent you can here it roaring in the rv and when you walk past outside,and the fridge doesn’t seem as cold now,could it be a faulty gas valve?any ideas?
  • I would start by cleaning the burner (supposed to be an annual maintenance item). Any LP pressure problem would be due to the main regulator, and all LP appliances would be affected.
  • Sometimes the roar is caused from too much air. Try cutting it back, you should have a blue flame with just a hint of yellow at the tips of the flame.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
