Bob_Landry
Mar 09, 2014Explorer
You are looking for 23 volts, not amps. Regardless, If you can hear any kind of sound coming from the compressor running and there is no cooling, it's dead. The wire I was talking about is a black wire that plugs onto a pin located on the bottom of the compressor. There is also a ground lug with two wires attached to it. If yours is any other configuration, then it is not a Norcold unit.
