mdcamping
Dec 14, 2022Explorer
Put a cup to catch any water on the out side drain, then let it defrost completly on the inside. If you find no water in the cup then you probably have food/dust plugged in the drain hose. If you can find some compressed air to blow out the drain from the outside, this will usually work
Good luck
Mike
Good luck
Mike
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
