dougrainer
Dec 14, 2022Nomad
Almot wrote:
Thank you, people. Likely the ice. Can't defrost it now, fridge is full. Will have to clean the tray daily so that it wouldn't overfill.
Doug, will all due respect to your knowledge in this area, ice on the fins and in the tray is related to freezer temps, albeit indirectly. Thermostat is in the fridge as I understand. It cycles when fridge temp rises to whatever the thermostat is set to. In warm weather with sun shining on the fridge side of trailer, I have to set thermostat to Max to keep freezer below 4. This causes fridge to cool below 32 and freeze water in the tray, and sometimes to grow an impressive ice fur on the fins before it starts dripping to the tray.
Sorry, It does NOT. The sunny problem you have has to do with the sun causing problems with convection air over the cooling unit coils. The freezer will get below 10 degrees(normal temp is zero to 10 degrees) regardless of 1 to 5 on the temp adjustment. What you need to do is install an extra cooling fan. If you have a standard 2 door Norcold, it may NOT have a external cooling fan. IF the refer is in a slide room you DO NEED a additional cooling fan blowing out the top access door. Post Year model and Model or Norcold. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
