wa8yxm
Dec 17, 2022Explorer III
Re the compressed air suggestion NOT GOOD IDEA IF ICE BLOCKED.
BUT YOU CAN GET A TUBE LONG ENOUGH AND THE NEEDED ADAPTER TO FEED IT A GOOD FLOW OF HOT WATER (TAKE THE OUTSIDE END OUT OF THE CUP THATS THERE AND ADD HOSE TO IT AS WELL LARGER HOSE SO IT RUNS ON THE GROUND) THIS WILL HELP CLEAR ANY OTHER BLOCKAGE.
Sorry about hitting caps lock.
I have found when the drain tube starts freezing... (This was on a residential not an RV unit) it tends to keep doing it
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
