Old-Biscuit
Mar 03, 2021Explorer III
Almot wrote:Gdetrailer wrote:
Some of the newer RV fridges have a makeshift T stat control, basically a thermistor attached to one of the cooling fins in the fridge section, you slide it up and down the fin to control the fridge temps.. No thermistor, no control you can adjust..
My 6 cu.ft Norcold has this thermistor on the fin. It's position has very little effect on the temperature or the On-cycle duration, not nearly as much as the thermostat position. Gas thermostat has High-Med-Low setting and I sometimes put it on the Low in the evening or when the freezer section is empty and/or items in the fridge section are not critical - and then it runs less often. Propane fridge sucks, but this is the easiest option in off-grid.
That is because the thermistor position should be fixed as the thermostat is OEM calibrated for temp range based on that thermistor position
Adjusting thermistor position UP/DOWN can affect fridge overall temps (minor affect 4*F - 6*F) IF---IF fridge uses an 'Automatic Temp Control' (No temp setting adjustments)
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
