jbrack wrote:
jbrack wrote:
Old-Biscuit wrote:
Not properly cooling on electric OR Propane is NOT a low amp issue
30A is NOT low amp issue either
Are the external fans running?
Is fridge in a slide out?
Airflow is CRITCIAL to cooling process......
IS this a Norcold 1200 model?
What error/fault codes are you getting?
What temps are freezer & food compartment achieving?
The Fridge is a 1210 model. It is in the slide. I get no error codes, it just doesn't get very cold. On the #9 setting, it is currently at 38 degrees. I am in Alberta, Canada at the moment and the outside temp is around 75.
There are no external fans that I am aware of or can find. The temp in the freezer is 28 degrees.
And when I said I suspect I had low amperage on at least two occasions, I meant that the entire park was serviced by an auxiliary generator. I know I had low amps because my microwave was groaning when I tried to use it. I didn't have this problem until I stayed at those two RV parks
