fourthclassC's avatar
fourthclassC
Norcold Fridge Questions
Got my fridge working great a while back. I was able to perform a hard reset and has been working great except for the occasional gas flame shut down due to rust scale falling from the inside the chimmney/ baffle. The fridge is on a 2003 Winnebago Mini, so its old and I am thankful it works so well, except for the rust scale. I have blown it out several times with compressed air and the scale comes back. Has anyone replaced the baffle or know of a way to fix/replace parts to eliminate the raining rust scale on a Norcold? Thank you
1 Reply
  • I pull them out, disassemble, and wire brush. I've never been able to clean much with an air hose or without disassembling. That should keep the rust down for quite a few years. That will also give you access to the tubing and cooling fins for cleaning and rust removal.
    On both ours, there are only 2 lag bolts in the rear, small trim screws at the front, 12V wiring, 115V plug, and a gas connection. It weighs less than 100 lbs. so I sit it on a rug and slide it out the door.
    You can disassemble the burner without removing the frig from the camper, I just like to sit on a bench where I can get to everything easy. When finish, I can then test it before putting it back in.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
